  3. Can a group of nets be forced onto specific layers with...
  • State Verified Answer
  • Views 8090
Can a group of nets be forced onto specific layers with CM?
Byron365
Byron365 over 3 years ago
I'm trying to see if I can use Constraint Manager in V17.2, to create a DRC if a group of nets are not kept on the same layer. For some FPGA bank routing the designer wants to ensure that routes within the same bank are kept on the same layer. Following this requirement is simple, but I'm not sure if a design rule can be created to force it and flag DRC's if it's not followed.
Can Constraint Manager control this?
  • JITHINDEV
    JITHINDEV over 3 years ago +1 verified
    Hi Byron365, One thing you can do. You can define the layers for particular signals/group of signals you want. By using electrical constraint >> wire>> layer set if not followed this there will be a DRC…
  • JITHINDEV
    +1 JITHINDEV over 3 years ago
    Hi Byron365,
    if not followed this there will be a DRC error.
    Cheers
    Jithindev
  • Byron365
    0 Byron365 over 3 years ago in reply to JITHINDEV
    Thanks JITHINDEV! That should do exactly what I need.
