  3. Prevent Allegro from declaring the path of the project file...
  • State Verified Answer
  • Views 8721
Prevent Allegro from declaring the path of the project file in the .art deliverables.
Tim Nagi
Tim Nagi over 3 years ago
By default, the second line of a “.art” file shows the full path of the source “.brd” project file. Here is a typical example:
G04 Layout Name:  M:/……./myProject.brd*
Is there some environment variable that would disabled this feature?
Thank you.
  • steve
    steve over 3 years ago +1 verified
    Yes you can. Go to Setup - User Preferences - Manufacture - artwork and enable the art_stripdirectoryname option,
  • steve
    steve over 3 years ago in reply to Tim Nagi +1 verified
    There isn't an option for that. You may have to just save the board as a different name designX.brd then process it as a workaround.
  • steve
    +1 steve over 3 years ago
  • Tim Nagi
    0 Tim Nagi over 3 years ago in reply to steve
    Thank you Steve.  It works fine.
    This command removed  the path, but kept the Layout name "myProject.brd" in the art files.
    Can we remove the Layout name as well?
  • steve
    +1 steve over 3 years ago in reply to Tim Nagi
  • Tim Nagi
    Thank you Steve.
