  3. What is the size/ block range for Ref-Des text on Silk screen...
  • State Suggested Answer
  • Answers 1
  • Views 8761
What is the size/ block range for Ref-Des text on Silk screen?
dp09
dp09 over 3 years ago
I am new at working with Cadence Allegro, learning new features every time I use it.
For silk screen text / Ref Des is there any font size range.? Please help with the list if so..
Also, how can we change the spacing between the text in Silk layer.
For Ex- A  B  C  D  E -->> need to change to ABCDE. Please suggest how to do so.
Thanks.
  • aniju
    aniju over 3 years ago +3 suggested
    In allegro text will work in text block sizes, You have set the text block sizes in Setup > Design parameters > Text > Setup Text sizes. after setting the text block, if you want to change the text,…
  • aniju
    aniju over 3 years ago +2
    You can adjust the text gaps based on the values below.
  • aniju
    0 aniju over 3 years ago
    after setting the text block, if you want to change the text, edit>change> go to option tab check on Textblock (uncheck all) and select apprapriate text.
    Please refer below article.
    Article (20480882) Title: How to change text size for group of text in Allegro PCB Editor
    URL: support.cadence.com/.../ArticleAttachmentPortal
    • Vote Up +3 Vote Down
  • aniju
    • Vote Up +2 Vote Down
