  3. Checkbox in the FORM in the OrCAD PCB Designer
  • Views 7720
JuriV
JuriV over 3 years ago
Hi Everybody,
I have a FORM with two Checkboxes e.g. "X" and "Y".
How to check which of the keys has been selected?
Example:
case( FORM  -> curField
           ("X"
            "Y"
                 if X Do something_1
                     else
                        Do something_2
               ); end if
        ); end case
  • Tolo1996
    0 Tolo1996 over 3 years ago
    You can try do this like this:
    (case fw->curField
    ("X"
    something_1
    t)
    ("Y"
    something_2
    nil
  • JuriV
    0 JuriV over 3 years ago in reply to Tolo1996
    Tahnks!!
    Additional Question:
    I want to use the function axlSingleSelectBox(). For example if X then axlSingleSelectBox()
               ("X"
                "Y"
                     if X axlSingleSelectBox()
                         else
                            Do something_2
                   ); end if
            ); end case
    If I do this I can't check "Y" again in my FORM, because the operation axlSingleSelectBox() is active.To check the "Y" the operation must be canceled in first. Is there another way to do that? Could be proved if the boxes are checked, before the axlSingleSelectBox() wil be start?
    Tahnks
