  3. Abnormal text size for UI
  • State Verified Answer
  • Replies 8
  • Subscribers 162
  • Views 9311
yu88
yu88 over 2 years ago
hi All,
i would like to ask did anyone got the same issue and solution for this?
Option and Find window text is smaller, while the visibility window is normal, maybe anywhere i can adjust it?
thanks in advance.
  • steve
    0 steve over 2 years ago
    Firstly make sure you are running the latest version of software (17.4-2019 S037 or 22.1-2022 S005) because there may have been improvements in the graphics performance in a hotfix release. If that doesn't help close Allegro and add a new Computer Environment Variable (Control Panel - System - Advanced System Settings - Environment Variables) Variable name ALLEGRO_HIGH_DPI_ENABLED with a value of 1. Once Confirmed restart Allegro and see if that helps.
  • yu88
    0 yu88 over 2 years ago in reply to steve
    hi steve, unfortunately my company is on 17.2 S083.
    for this one, i have tried before but not helping too. May i know what is this setting for?
  • yu88
    +1 yu88 over 2 years ago in reply to steve
    lastly i solve this by adjusting fontsize in User Preference Editor
    • Vote Up +2 Vote Down
  • JuanCR
    0 JuanCR over 2 years ago in reply to yu88
    Hi yu88,
    ALLEGRO_HIGH_DPI_ENABLED is a Windows environment variable that is set to 1 in machines that use high resolution displays (4K dispalys). However, this mostly solve issues with forms that are clipped. Your issue seems to be more related to fontsize, like you mention in your following post. Did changing the font size solve the issue completely?
  • Robert Finley
    0 Robert Finley over 2 years ago
    Did you reinstall windows or a new machine?   [Windows Button] Display settings>  Scale and Layout>  increase that maybe?
