  3. IPC-D-356A Netlist vs Gerber Files
  • State Suggested Answer
  • Answers 1
  • Subscribers 166
  • Views 14768
BaldEngineer
BaldEngineer over 3 years ago
Hi
I was recently informed by my PCB Manufacturer that there is some short, broken connections when they compare Gerber(art) data with IPC-D-356A Netlist data i sent them.
I can't see anything wrong both on Gerber data and my board file.
So, was wondering if there is any way to compare Gerber data with IPC Netlist and find where the fault is(if any)?
Thanks for help.
  • aniju
    aniju over 3 years ago +1 suggested
    I think you may use any gerbers tools like CAM350 to do IPC netlist compare. CAM350 will support netlist compare but you have to to check other CAM tools.
  • jc teyssier
    0 jc teyssier over 2 years ago in reply to DavidJHutchins
    Sound pretty good.
    Is it possible for you to share these scripts?
