  3. Via shape fill
  • State Suggested Answer
  • Answers 1
  • Subscribers 162
  • Views 8171
Via shape fill
Edit slide getting closed
Edit slide getting closed over 2 years ago
Need connect shape but via area not connecting. Please help on this. Dimension in mm.
  • steve
    0 steve over 2 years ago
    You have two options, 1 reposition the vias to allow the shape to pour through the space or 2 reduce the via - shape spacing rule to allow the copper to flood the area.
  • Edit slide getting closed
    0 Edit slide getting closed over 2 years ago in reply to steve
    Not possible to move via because BGA package.
    Option 2 where to change?
  • steve
    0 steve over 2 years ago in reply to Edit slide getting closed
    Constraint Manager - Spacing. You could add a Constraint Region (Rules by Area) to drive just this section or update the default rule of via to shape. Look at YouTube channel parsyseda which have videos covering this type of setup.
  • masamasa
    0 masamasa over 2 years ago
    in addition to steve's comments, u need to set up enough shape width on the shape parameter if the shapes are dynamic shapes
    Not Updating. Still shape not filling any other option
