  3. Differnce between net class and net group.
  • State Suggested Answer
  • Answers 1
  • Views 14184
Ram1234
Ram1234 over 3 years ago
Hi all,
Good day!...
I am little confisued between net class and net group in constraint manager.
Please clarify where to use net class and net group for me.
which one do I need follow up to?
  • aniju
    aniju over 3 years ago +1 suggested
    Assume, You have created Net class in Electrical constriant, you have to set the constriants with in the electrical constriants set. Assume, you have created Netgroup in electrical constriant, This can…
  • masamasa
    0 masamasa over 3 years ago
    you can refer to the following site:
    https://community.cadence.com/cadence_technology_forums/pcb-design/f/pcb-editor-skill/44015/create-a-new-constraint-group-or-constraint-class
  • Ram1234
    0 Ram1234 over 3 years ago in reply to masamasa
    Hi masamasa
    Good Day!....
    thanks for the reply...
    I have already read the post, but after studying it, I am even more puzzled. Could you please assist me in better understanding it?
  • aniju
    0 aniju over 3 years ago
    Assume, you have created Netgroup in electrical constriant, This can be used with Electical, Physical, Spacing, Same net spacing constriants sets.
    here are the screenshots. I have created  Net-class as 'TEST' and 'NG2' as a Net-group, TEST stays in  with electrical constraints set only but NG2 will have it physical, spacing and other constraints set as well.
    now i moved to physical constriants set, we can set physical constraints for NG2 net group, here is the image.
    Net group can be member of net class but net class cannot be a member of netgroup because net class is local and netgroup is global. Net classes is applicable when you have a specific requirements to the nets.
    Please refer below article for more differences.
    Article (20460969) Title: What is the difference between a Net Group and a Net Class in Constraint Manager?
    URL: support.cadence.com/.../ArticleAttachmentPortal
  • Ram1234
    0 Ram1234 over 3 years ago in reply to aniju
    Hi aniju
    Thanks for the reply...
    I got a basic understanding of the calss and groups.
    According to what I understand, the net group needs to be included within the net class.
    Kindly correct me if I'm mistaken!
  • aniju
    0 aniju over 3 years ago in reply to Ram1234
    its not always netgroup should be included in the netclass, if you have specific requriements to those nets, you may include it in the netclass.
