  3. read and assign color of via
  • State Suggested Answer
  • Answers 1
  • Subscribers 166
  • Views 8849
Mhawley1
Mhawley1 over 2 years ago
Hey everyone .
How do I get the color assigned to the via?  I am looking for a GET and SET routine on those elements .
  • masamasa
    0 masamasa over 2 years ago
    u perform the assign color command then in the find filter u select vias.
    on the options pane, u select a color.
    then u select vias that u want to change.
    if u want to set up a funckey, the following could be used.
    funckey k "assign color form.find;FORM find all_off; FORM find vias YES"
    if u press the "k" key, it already selects only vias.
    the funckey has to be placed on ur env file bfore opening ur design file.
  • Schulz Jordan
    0 Schulz Jordan over 2 years ago in reply to masamasa
    You can assign color to vias on each layer using color dialog box
  • Hoangkhoipcb
    0 Hoangkhoipcb over 2 years ago
    Try this one.
