  3. Via mirroring issue
  • State Suggested Answer
  • Answers 1
  • Views 9715
Via mirroring issue
DBTCH
DBTCH over 3 years ago
Hi everybody ,
I need to mirror via with user layer on Mask layers Padstack  .
When I mirror the via the Top to Bottom data are only exchange for the copper,soldermask and pastmask .
I have additional user layer with "_Top" and "_Bottom" at the end of the layer_name  but there are not swap when I mirror the via .
Is there only the default layer that can be swap from Top to Bottom or I need to set the pairing of my custom layer ?
I hope thats clear Wink
Best regards
  • John T
    0 John T over 3 years ago
    Yes In this case the current workaround is to create a second via padstack with with user layer pad on bottom. The code which performs mirroring of user layers is linked with a symbol not vias and depends on the mirror flag being set on the symbol.
  • DBTCH
    0 DBTCH over 3 years ago in reply to John T
    Thank you for confirming what I thought .
    In my case I use a skill to panelize and if I mirror a module there are some issue with via with user layer .
    The only workaround is to replace via in mirror modules but very risky Angry .
  • John T
    0 John T over 3 years ago in reply to DBTCH
    It is possible to replace vias with via structures. This can be done by Route > Via Structure > Replace Via with Via Structure. I say this because via structures behave like symbols, so it may be worth checking if the mirror feature performs better for your particular circumstance.
  • masamasa
    0 masamasa over 3 years ago in reply to DBTCH
    what is the reason for mirroring the vias while panelizing?
    r u creating the actual vias from the backside?
