  3. Lock PCB footprints entities
  • State Verified Answer
  • Subscribers 159
  • Views 8564
Arsalan1001
Arsalan1001 over 2 years ago
We use to receive PCB footprints from our part creation team but different entities (like route and via keep-out, lines on silk screen and designator) of footprint use to be not locked.
Is there a way to lock the footprint entities to avoid deletion of any entity of footprint?
Note: Please note my query is not related to position lock of footprint in PCB. It's about locking the footprint so any entity of footprint does not delete while we remove something else on layout.
Thank You
  • DBTCH
    0 DBTCH over 2 years ago
    Hi ,
    You need to add Locked property at Drawing level in the symbol editor .
    Edit property -> Find by name select Drawing and add Locked property .
    Best regards
    • Vote Up +2 Vote Down
  • Arsalan1001
    0 Arsalan1001 over 2 years ago in reply to DBTCH
    DBTCH Thanks for your response. Is it something can only be done In library only? As I don't have access to library so am wondering if there is a way to do it in layout?
  • DBTCH
    0 DBTCH over 2 years ago in reply to Arsalan1001
    Unfortunately, this has to be done in the library and footprint by footprint .
  • eDave
    0 eDave over 2 years ago in reply to Arsalan1001
    I You can just add the LOCKED property to each symbol within the design.
  • Arsalan1001
    0 Arsalan1001 over 2 years ago in reply to eDave
    eDave could you please explain, how I can add lock properties in layout? I tried but not successful.
