  3. how to increase menu text size in 17.4?
  • State Verified Answer
  • Views 9991
avant
avant over 3 years ago
I installed Allegro 17.4. The menus and text size is too small.
I increased the font size, but it did not increase menu size and text size in the pull down tabs.
17.4 inherited the 17.2 setting I had set up, but the text is too small.
What are some things I can do to fix this?
  • steve
    steve over 3 years ago +1 verified
    Close Allegro and add a new PC environment variable (Control Panel - System - Advanced - Environment variables) called ALLEGRO_HIGH_DPI_ENABLED with a value of 1. Then restart Allegro. You may have to…
  • steve
    +1 steve over 3 years ago
    Close Allegro and add a new PC environment variable (Control Panel - System - Advanced - Environment variables) called ALLEGRO_HIGH_DPI_ENABLED with a value of 1. Then restart Allegro. You may have to undo the fontsize variable setting as well.
  • avant
    0 avant over 3 years ago in reply to steve
    Thank you Steve! 17.4 is now usable.
