  3. Footprint Cutout Not Updating on Layout
  • State Suggested Answer
  • Answers 2
  • Views 8799
Shannonlee
Shannonlee over 3 years ago
I created a footprint with internal cutout at the center. However, when placing footprint on layout, it doesn't show the outline of footprint nor cutout. I've tried update symbol and still no changes on layout or 3D canvas.
  • SandeepVarrier
    SandeepVarrier over 3 years ago +2 suggested
    You can create slot Non-plated using the padstack editor and place.
  • JITHINDEV
    JITHINDEV over 3 years ago +1 suggested
    Hi Shannonlee, can you check that whether you have added BOARD GEOMETRY >> CUTOUT ? For the silk outline you have to select the Lines while opening 3D Canvas images are for reference
  • Shannonlee
    Shannonlee over 3 years ago in reply to JITHINDEV +1
    Hi JITHINDEV, I checked that I was able to see the cutout of the footprint in the viewer. When I check the PCB editor, it doesn't show up at all, only the Place_Bound_Top View of the footprint…
  • JITHINDEV
    0 JITHINDEV over 3 years ago
    Hi Shannonlee,
  • Shannonlee
    0 Shannonlee over 3 years ago in reply to JITHINDEV
    Hi JITHINDEV,
    View of the footprint drawing with cutout and pins, and right side is the 3D canvas showing cutout
    3D canvas of the board, even when I removed view of components, the cutout doesn't show at all.
  • JITHINDEV
    0 JITHINDEV over 3 years ago in reply to Shannonlee
    Hello, Shannonlee
    in the board BOARD GEOMETRY >> CUTOUT must work in footprint as well as your Layout file if added.
    Additionally, the cut-out can be drawn directly in the Layout file (.brd file) itself.
    Try that with BOARD GEOMETRY >> CUTOUT and add using shape tools.
    NB:- The cutout must be appropriately updated during component movement.
  • SandeepVarrier
    0 SandeepVarrier over 3 years ago
    • Vote Up +2 Vote Down
