  3. Removing unused pins on a Footprint
  • State Suggested Answer
  • Answers 2
  • Subscribers 167
  • Views 9035
gazza47
gazza47 over 3 years ago
Hello
Can you advise how or if I can remove Unused pins on a Footprint
The Attached Image is a Toroid which was originally going to be mounted on a PCB and Tied Down, however the Component is now being mounted through a Cutout in the PCB onto the chassis below. As a result the 6 internal Mechanical Pins can be deleted as they are situated in the cutout.
The question is how can I delete these? I can select and move them but can't delete them
Any solutions appreciated
Many Thanks
  • steve
    0 steve over 3 years ago
    You would need to modify the symbol (footprint) of this part to remove any unrequired pins. If you have access to the library location (psmpath) open the filename.dra and delete the pins. Then save. Back in the board use the Update Symbols (Place menu) command to refresh the updated symbol. If they are mechanical pins that should be that. If they are electrical pins (have a pin number) you would also need to ensure that the corresponding schematic symbol matched the pin count..
  • Arsalan1001
    0 Arsalan1001 over 3 years ago in reply to steve
    steve Is there a way to remove the pin inside BRD file if no access to library?
  • masamasa
    0 masamasa over 3 years ago in reply to Arsalan1001
    u can export the library from ur design.
