  3. dxf out question
  • Replies 11
  • Views 13126
dxf out question
masamasa
masamasa over 3 years ago
hello
is there a way to maitain the assigned color on the bga pads on the design during the dxf export?
the exported dxf file has always white colored pads.
regards
masa
  • masamasa
    0 masamasa over 3 years ago in reply to DavidJHutchins
    thank u for checking, david.
    r u talking about the colors assigned by the command "assign color"?
  • DavidJHutchins
    0 DavidJHutchins over 3 years ago in reply to masamasa
    No, I just verified that the layer colors in a pcb fab_dwg matched between Allegro and  the dxf file
    Per research I did a couple of years ago the only way to export 'assign color' setting is to use the 'capture image' command
  • masamasa
    thank u, david. the purpose of this dxf out is to find out the xy coordinates of the highlighted bga pads assigned by the command assign color.  so a capture Image does not help.
  • DavidJHutchins
    As a possible solution to that issue I wrote the skill code below to report the colored pins:
    procedure((Report_ColoredPins \@optional FileName)
        prog((OutputName outport PinCnt NetCnt Total)
            if(FileName then
                (OutputName = strcat(simplifyFilename(".") "/" FileName))
                (OutputName = FileName) else
                (OutputName = strcat(simplifyFilename(".") "/Colored_Pins.txt"))
            if(isFile(OutputName) then
                unless(deleteFile(OutputName)
                    (axlMsgPut "ERROR: could not remove existing file %s" OutputName)
                    return()
            (axlMeterCreate "Report 1 pin nets" "" t)
            if((outport = outfile(OutputName)) then
                (NetCnt = 0)
                (PinCnt = 0)
                (Total = length(((axlDBGetDesign)->nets)))
                foreach(net
                    unless((axlMeterIsCancelled)
                        NetCnt++
                        (axlMeterUpdate
                            ((100 * NetCnt) / Total)
                            strcat("Processing net "
                                (net->name)
                        foreach(branch
                            (net->branches)
                            foreach(child
                                (branch->children)
                                when(((child->objType) == "pin")
                                    when((axlIsCustomColored child)
                                        PinCnt++
                                        fprintf(outport "%s.%s\t%s\t(%g %g)\t%d\n"
                                            ((child->component)->name)
                                            (child->number)
                                            (net->name)
                                            (xCoord
                                                (child->xy)
                                            (yCoord
                                                (child->xy)
                (axlMeterDestroy)
                close(outport)
                (axlMsgPut "%d nets processed, %d CustomColored Pins found & written to %s" NetCnt PinCnt OutputName) else
                (axlMsgPut "ERROR: could not open output file %s" OutputName)
                return()
  • masamasa
    thank u, david for providing me with the skill coade.
    i am not familiar with skill codes.
    In the skill caode named "color_assign.il", do i need to put something in the head shown below?
    axlCmdRegister( "color_assign" `color_assign)
    skill code continued
