  3. dxf out question
  • Replies 11
  • Views 13132
dxf out question
masamasa
masamasa over 3 years ago
hello
is there a way to maitain the assigned color on the bga pads on the design during the dxf export?
the exported dxf file has always white colored pads.
regards
masa
  • DavidJHutchins
    0 DavidJHutchins over 3 years ago in reply to masamasa
    I included the command registration & added design units output
    updated skill code below:
    procedure((Report_ColoredPins \@optional FileName)
    prog((OutputName outport PinCnt NetCnt Total)
    if(FileName then
    (OutputName = strcat(simplifyFilename(".") "/" FileName))
    (OutputName = FileName) else
    (OutputName = strcat(simplifyFilename(".") "/Colored_Pins.txt"))
    if(isFile(OutputName) then
    unless(deleteFile(OutputName)
    axlMsgPut("ERROR: could not remove existing file %s" OutputName)
    return()
    axlMeterCreate("Report Colored Pins" "" t)
    if((outport = outfile(OutputName)) then
    (Total = car((axlDBGetDesignTotal)))
    cond(((Total == "mils")
    fprintf(outport "UNITS Mils\n")
    ((Total == "inches")
    fprintf(outport "UNITS Inches\n")
    ((Total == "microns")
    fprintf(outport "UNITS UM\n")
    ((Total == "millimeters")
    fprintf(outport "UNITS MM\n")
    ((Total == "centimeters")
    fprintf(outport "UNITS CM\n")
    (NetCnt = 0)
    (PinCnt = 0)
    (Total = length((axlDBGetDesign()->nets)))
    foreach(net
    unless(axlMeterIsCancelled()
    NetCnt++
    axlMeterUpdate(((100 * NetCnt) / Total)
    strcat("Processing net "
    (net->name)
    foreach(branch
    (net->branches)
    foreach(child
    (branch->children)
    when(((child->objType) == "pin")
    when(axlIsCustomColored(child)
    PinCnt++
    fprintf(outport "%s.%s\t%s\t(%g %g)\t%d\n"
    ((child->component)->name)
    (child->number)
    (net->name)
    xCoord((child->xy))
    yCoord((child->xy))
    axlMeterDestroy()
    close(outport)
    axlMsgPut("%d nets processed, %d CustomColored Pins found & written to %s" NetCnt PinCnt OutputName) else
    axlMsgPut("ERROR: could not open output file %s" OutputName)
    return()
    axlCmdRegister( "Report_ColoredPins" 'Report_ColoredPins)
