  3. Show Test Point connected net in footprint
  • State Suggested Answer
  • Answers 1
  • Subscribers 166
  • Views 8480
masterboyle
masterboyle over 3 years ago
I want to make a simple one pin test point footprint .dra symbol. I want to make it display the connected net or "part of net" property for the pin on the package geometry silkscreen top layer so that when I use it in the design, the connected net displays and moves with the footprint. Right now the only way I know how to do this is to add the connected net text manually once I'm in the pcb design tool. But then this gets problematic when you need to start moving test points around. Is there any way to accomplish this at the footptint level?
  • avant
    avant over 3 years ago +1 suggested
    Just add some text on the appropriate silkscreen layer to the footprint. After test point is placed on the board, edit the (silkscreen) text to be the net name. The test point can be moved and the…
  • John T
    0 John T over 3 years ago
    Can you please tell us what version of Allegro you are using? (17.2, 17.4, 22.1 etc..) To clarify, you want to display the pin net name in silkscreen layer, is that correct? If you create a testpoint dra, then the net name shall appear in the pad already. Do you have a particular requirement for showing this net in the silkscreen gerbers?
  • avant
    0 avant over 3 years ago
    The test point can be moved and the net name in silk will stay attached.
  • Jim OMahony
    0 Jim OMahony over 3 years ago
    You might like to try this skill routine. It works in layout. Add the file to your pcb directory and type
    skill load("add_net_ref_v1-3_forum.il")
    Then type the command addnetref. There is a help file to explain how it works.
    I have no doubt that there are plenty of improvements that could be made to the Skill code, so if
    anyone wants to post updated versions feel free to do so.
    Jim O'Mahonyhttps://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/add_5F00_net_5F00_ref_5F00_v1_2D00_3_5F00_forum.zip
