  3. place replicate manually match parts ?
  • Views 7845
Jessicak
Jessicak over 3 years ago
I have 6 identical circuits with the exception of some component values. My library treats different values as different parts. I can understand this could throw the matching algorithm off, but for the few parts that are different I could easily match them manually and they are the same footprint . But I cannot find a way of doing this. Is it possible?
Secondly the identical circuit is itself two identical circuits but linked at input and output (redundant circuits) but the algorithm swaps the top and bottom circuit parts around without an option to swap them back. I thought you had that option to select. it is also strange that the references are the same apart from a page prefix such as R2300 and R2400 and still seems to choose not to align in order.
I am using SP22.1-2022-S004
Anyone able to advice Please?
Thank you
Jessica
  • SandeepVarrier
    0 SandeepVarrier over 3 years ago
    while doing a place replicate if the seed circuit is not matching the set of components selected to match then a popup window appears which can be used to match the rest of the components by swapping.
    the connections which are replicating also matches the pin numbers , which can lead to wrong mapping., try changing the orientation of the connection
