  3. Run dev_check on device file for more information.
  • Views 9819
Ram1234
Ram1234 over 3 years ago
Hi Team,
Good day!
How to run the Run dev_check,
where can I find this option and how do I run it?
Please help me to fix this error.
"" Pin numbers do not match between symbol and component. Run dev_check on device file for more information.",
I know this error is because the symbol and footprint pins are not matched.
To find the error, we need to run the dev_check, so please help me find the procedure to fix.
  • VVRD
    0 VVRD over 3 years ago
    Hi Ram,
    You should see these errors while creating or importing netlist. Check below information:
    The dev check batch command that compares device files and package symbol definitions and generates a log file listing any discrepancies.
    This command automatically:
    • Checks the syntax of the device files specified in the command.
    • Creates a temporary netlist called dev_check.net, which consists of the $PACKAGES section of the netlist file.
      The dev_check.net file contains no information and is used only to check symbols against the device files. The $PACKAGES file section creates U1, U2, U3 and so on, sequentially.
      The dev_check command creates a temporary drawing called dev_check.brd and runs the netin command, which loads a $PACKAGES section of a netlist into the drawing so that the editor can check the devices and symbols in the drawing.
    • Creates a dev_check.log file which contains a netin.log.
    • Identifies any errors as listed in the netin.log and displays them on the screen.
    Ensure that your environment path points to the proper directories for padstack files (PADPATH), device files (DEVPATH), and symbol files (PSMPATH) so that the tool can access the correct padstacks, devices, and package symbols.
    dev_check [-version] <device_filename>.txt
