  3. Cline connecting to corner of Pad not center
  • State Verified Answer
  • Replies 9
  • Answers 2
  • Subscribers 163
  • Views 8191
BrCoRo
BrCoRo over 1 year ago
Hi all,
I'm working with a QFN50P900X900X100-65N footprint but for some reason the traces going to it will only ever connect to the corner of the SMD pad not the center, any ideas?
I've gone into the package footprint DRA file and that also has the same issue, so I'm assuming its something with the PAD file?
I'm working on 17.4 if that helps.
Thank you in advance,
Kind regards
B
  • BrCoRo
    0 BrCoRo over 1 year ago in reply to bengelJF
    Hi bengel
    Thanks for the explanation. You're right in assuming it's a downloaded file, was hoping to save time with it being an IC.
    in future i'll just make the footprint from scratch as it'll be less frustrating than something as small as an incorrect pad origin point.
    B
  • AL202512303326
    0 AL202512303326 8 months ago in reply to bengelJF
    Hi! I've been facing the same issue as the original poster. I identified the issue as the origin being in the wrong place, and fixed the padstack file file, but no matter how I refresh (refreshing the padstack in the footprint file, or in the PCB itself), the issue persists in the PCB editor. Any idea how I could fix it?
  • digital1
    0 digital1 8 months ago in reply to AL202512303326
    was the padstack generated from a shape or a proper padstack generated in padstack editor to check if it is a shape open the padstack in padstack editro and it will tell you if it is a rectangle or shape.
    If it is a shape if you have the shape file open it in pcb editor and move the origin
  • AL202512303326
    0 AL202512303326 8 months ago in reply to digital1
    Yep, that solved it. Thank you!
