  3. Cline connecting to corner of Pad not center
  • State Verified Answer
  • Replies 9
  • Answers 2
  • Subscribers 168
  • Views 12153
istBrook
istBrook over 3 years ago
Hi all,
I'm working with a QFN50P900X900X100-65N footprint but for some reason the traces going to it will only ever connect to the corner of the SMD pad not the center, any ideas?
I've gone into the package footprint DRA file and that also has the same issue, so I'm assuming its something with the PAD file?
I'm working on 17.4 if that helps.
Thank you in advance,
Kind regards
B
  • masamasa
    masamasa over 3 years ago in reply to istBrook +1 suggested
    u need to make sure that the origin of the n9857253 symbol is the center of the n9857253 pad. it looks like u assigned the origin at the corner of the pad.
  • bengelJF
    bengelJF over 3 years ago in reply to istBrook +1 verified
    Footprint files (.DRA) reference padstack files (.PAD) when they're being built. If you do a right-click > Show Element, it'll tell you the name of the padstack, which should let you search for it on your…
  • masamasa
    0 masamasa over 3 years ago
    u need to make sure that "snap to connect point" is on when routing.
  • istBrook
    0 istBrook over 3 years ago in reply to masamasa
    I've made sure it is and this is what i'm getting
    hope that show it clearly
    B
  • masamasa
    0 masamasa over 3 years ago in reply to istBrook
  • istBrook
    How can I move the origin on the PAD file? does it have to be done within the DRA file of the footprint? or somewhere else?
    B
  • bengelJF
    +1 bengelJF over 3 years ago in reply to istBrook
    Footprint files (.DRA) reference padstack files (.PAD) when they're being built. If you do a right-click > Show Element, it'll tell you the name of the padstack, which should let you search for it on your system.
    If this is a footprint downloaded from the manufacturer or a third-party archive such as SnapEDA, the padstack file is likely bundled with the rest of the files in that download. (Based on the name, I suspect this is the case.)
    You may find out that it's quicker and easier to make your own padstack than to try to fix the existing one.
    For what it's worth, I've been burned too many times by downloaded footprints. We build up all our footprints from the manufacturer's datasheets using a common set of settings which avoids any issues from generated footprints or somebody on SnapEDA doing a poor job.
