  3. How to enable SLKSCREEN ; Allegro Physical Viewer 17.4
  • State Suggested Answer
  • Answers 1
  • Views 9137
atz000
atz000 over 3 years ago
Hi
I'm looking for how to enable SILKSCREEN.
Could anyone advise on this?
  • mahimag
    0 mahimag over 3 years ago
    Hi, Do you see the silkscreen layers in the Objects and Areas section?  Objects & Areas sub section lists all the design layers including mask and silkscreen layers.
  • DavidJHutchins
    0 DavidJHutchins over 3 years ago in reply to mahimag
    Another option would be to look at the Views entries, there typically is at least 1 silkscreen entry
  • atz000
    0 atz000 over 3 years ago in reply to DavidJHutchins
    Thanks, now I could see silkscreen when select Film; silk_prm on Views entries.
    I expected silkscreen would be appeared on layers and object section...
