  3. Is there any way to show the net length when sliding traces...
  • State Verified Answer
  • Views 9547
Is there any way to show the net length when sliding traces?
avant
avant over 3 years ago
I have a JEDEC reference board with no electrical constraints.
I need to adjust some changed traces to match the original net lengths.
Is there a way to display the net length when sliding?
I'm not prepared to add min/max trace length constraints to the nets, and may have to slide, inquire, slide, until I match the length.
  • JuanCR
    JuanCR over 3 years ago +2 verified
    Hi There is an env variable called allegro_etch_length_on . When you set this variable, you'll see feedback on screen after using the Route - Add Connect command. However, you can also set up a similar…
  • JuanCR
    +1 JuanCR over 3 years ago
    Hi
    There is an env variable called allegro_etch_length_on. When you set this variable, you'll see feedback on screen after using the Route - Add Connect command. However, you can also set up a similar result by using the command funckey and the slide command. As an example, I'll assign it to the letter s:
    funckey s "slide; etch length"
    Now, when you press "s" in your keyboard, you'll see the slide command activate with the etch length window on top. Let me show you how it looks:
    I've created a trace that measures 1 mm:
    After assigning the slide command with the etch length add-on to the letter "s" and using it, I've modified the trace like this:
    Notice how the pop-up window shows "0.2071".
    Now, if we use show element on the cline:
    See how the etch length changed in the amount that the pop-up window showed.
    • Vote Up +2 Vote Down
  • avant
    0 avant over 3 years ago in reply to JuanCR
    Thanks, I looked into that function.
    This function may work for me. I can find the difference between the new and old, and slide to match the difference.
    I appreciate the help.
  • masamasa
    0 masamasa over 3 years ago in reply to avant
    fyi:
    u may be aware of this but if u need to adjust the length of clines, u can copy the cline to the left or right or up or down with a specific amount.
    for instance, after selecting a segment of clines, u type copy in the command line, then type ix 50, which means copy the cline to 50um to the left.
     if u type iy -50, that would mean copying the cline with -50um in the y direction.
  • masamasa
    0 masamasa over 3 years ago in reply to masamasa
    another way is to type add connect, then select the cline and type ix 50 or iy -50.
