  3. OBD++ Error
  • Replies 9
  • Subscribers 160
  • Views 8823
OBD++ Error
Arsalan1001
Arsalan1001 over 2 years ago
When I try to export ODB++ , I receive following error. We are having same error i.e. "log file does not exist" with different designs and ODB++ file did not created for any design.
what could be possible issue and any fix ?
Thank You
Best Regards,
  • VVRD
    0 VVRD over 2 years ago
    Check if you have ALLEGRO_BRD2ODB env variable set to your brd2odb file, it usually should be C:\MentorGraphics\ODB++_Inside_Cadence_Allegro\brd2odb_2211.
    Thank you
  • Arsalan1001
    0 Arsalan1001 over 2 years ago in reply to VVRD
    VVRD thank you for your response but I don't see ALLEGRO_BRD2ODB. How to fix this, please.
  • VVRD
    0 VVRD over 2 years ago in reply to Arsalan1001
    Go to your system properties, in Advanced tab, select Environment Variables, In your System Variables, add ALLEGRO_BRD2ODB as shown in below snapshot.
    Thank you.
  • Arsalan1001
    VVRD thank you for your response. I think mentioned variables is already added, as shown below.
  • VVRD
    Can you try to execute brd2odb.exe and check if it is showing any error like missing .dll files?
