  3. Waived DRC
  • State Suggested Answer
  • Replies 7
  • Answers 1
  • Subscribers 161
  • Views 9277
Waived DRC
PCB6453
PCB6453 over 2 years ago
I would waived a DRC error on the design with or without a comment.  But once I "Update DRC", it keeps on coming back.  Also, as an example, once I "Update DRC", the errors shows "0", which is good.  Without closing the Status window, I will "Update DRC" again and more errors shows up (lets say 5).  Without closing the window again, I will "Update DRC" again and the number of errors changes again.  It is a random quantity and I believe it has something to do with the "Waived DRC errors".
Has anyone encountered this issue?  This came from a previous design database so I'm not sure if it was a setting issue somewhere.
  • oldmouldy
    0 oldmouldy over 2 years ago
    There has been a very rare issue with this in the past. The waived DRCs are handled by internal methods that have changed over time and this can cause what you are seeing. The "cure" is to make a note of the currently waived DRCs, restore all the waived DRCs, save the BRD file, and waive the DRCs again.
  • Schulz Jordan
    0 Schulz Jordan over 2 years ago in reply to oldmouldy
    Which version of software you are using ?
  • TCHA
    0 TCHA over 2 years ago in reply to Schulz Jordan
    @PCB6453, are you seeing this on other designs also? Can you let us know the version and hotfix you are working on?
    • Vote Up +2 Vote Down
  • PCB6453
    0 PCB6453 over 2 years ago in reply to Schulz Jordan
    Allegro PCB Venture 17.4 S034
  • PCB6453
    0 PCB6453 over 2 years ago in reply to TCHA
    Allegro PCB Venture 17.4 S034.  I'm not seeing this on other designs.  It is just this one particular file that was generated from a previous design.  The previous design also had the same issue.
