  3. Allegro free view setup - change mouse settings
  • State Verified Answer
  • Answers 1
  • Subscribers 166
  • Views 4355
RRMM
RRMM over 3 years ago
I am new to Allegro and I am trying to get the free viewer setup.
How do you change the mouse panning direction?
The default mouse setting is backwards to my thinking.
There does not seem to be an user setting in the menus so I assume the must be configuration file somewhere and some details/syntax on the settings available.
Can anyone educate me on getting setup?
  • cedar
    cedar over 2 years ago in reply to steve +1 verified
    found it thanks to the full version of allegro. in free viewer cli, type : set designhdl_pan = 1 you might need to set that variable in the env file.
  • steve
    0 steve over 3 years ago
    There is a user preference in Allegro (Setup - User Preferences - UI - Input called designhdl_pan which controls the direction of the pan. The viewer will use these variables so if you can set that using Allegro the restart the Viewer you should get the desired result.
    • Vote Up -1 Vote Down
  • cedar
    0 cedar over 2 years ago in reply to steve
    this option is not available in the free version. nor is there any ui user preferences menu. what is the command to toggle that option in the cli?
  • cedar
    +1 cedar over 2 years ago in reply to steve
