  3. Auto Placebound of footprints
  • Views 7546
jmh299
jmh299 over 3 years ago
I am using PCB Editor 17.4, when I generate a footprint.  I define the placebound top and DFA bound top.  When I place a component on my PCBs it seems that PCB Editor is still auto generating a place bound top....is there any way to disable this?
  • VVRD
    0 VVRD over 3 years ago
    To stop the placebound shape automatically created for the DRA symbol without the placebound being present you can follow any one of the below methods:
    1. You can add the drawing-level property (Sym_No_Placebound) in the DRA file before creating their final library symbol.
    To add this property, use the following steps:
    Open the .dra file.
    Select Edit > Properties.
    In the Find By Name field, select Drawing. It will open the Edit Property window.
    Select the Sym_No_Placebound property from the Available Properties list.
    2. In Setup > Design Parameter, there is an Auto create place bound checkbox. If you do not want auto creation of placebound, you can uncheck this checkbox.
  • avant
    0 avant over 3 years ago in reply to VVRD
    Thanks! after 25 years of using Allegro, I still learn new things.
