  3. Panelization Syncronization Issue
  • State Verified Answer
  • Views 7578
BaldEngineer
BaldEngineer over 2 years ago
Hi
I have been using Panelization Tool to in PCB Editor for a while now.
Today, i updated something in the individual PCB so that i could import it in the Panelzation Tool.
As soon as i uploaded the new board file in Panelization Tool and tried to Syncronize the Stackup under 'Setup' Window, PCB Editor crashes.
It won't work. I tried it several times and always hangs.Using 22.1.007 version.
  • BaldEngineer
    BaldEngineer over 2 years ago in reply to John T +1 verified
    Hi I found out that the issue was related to the location of the Panel.brd and PCB.brd at different positions as these 2 were present under different folders. I moved both of them under same folder and…
  • John T
    0 John T over 2 years ago
    Hi , can you please try opening Allegro in safe mode by invoking it from the command prompt by typing "allegro -safe". Alternatively, please also try to launch the program as an administrator by using right mouse button on your Allegro.exe icon. Select Run As Administrator. Let me know how you get on with either of these steps.
  • BaldEngineer
    +1 BaldEngineer over 2 years ago in reply to John T
    I moved both of them under same folder and it started working. I guess in my case, the location string was also bit long as i experience every now and then that it causes problems while saving if the file is present maybe 10 folders deep.
