  3. Gerber format options that to be selected.
  • State Verified Answer
  • Views 7948
Ram1234
Ram1234 over 2 years ago
Hi Team,
Good day!
While generating the Gerber files,
Which checkboxes should be selected, and why, especially concerning the suppression options and the apertures?..
Please help us understand in depth.
  • SandeepVarrier
    SandeepVarrier over 2 years ago +1 verified
    The Device type field specifies the plotter model: Gerber 274 X is used mostly this is dependent on the format the manufacturer requires the file Suppression : The Suppress fields control whether…
  • SandeepVarrier
    +1 SandeepVarrier over 2 years ago
    Suppression :
    The Suppress fields control whether the PCB Editor tool writes leading or trailing zeroes or equal coordinates in the Gerber data file. You cannot suppress both leading and trailing zeroes. Selecting Equal coordinates reduces the size of the Gerber data file.
    Any zeroes appearing to the left of the first non-zero digit (of any integer or decimal) do not affect its value, and can be omitted: Suppress leading zeros
    similarly the trailing zeros after the decimal point non-zero digit which can be insignificant: Suppress trailing zeros
    If there are more than one data at a specific coordinate then the coordinates are not repeated in the Gerber file: Suppress EQUAL
    SUPPRESS-LEAD-ZEROES  YES
    SUPPRESS-TRAIL-ZEROES NO
    SUPPRESS-EQUAL   YES
  • Ram1234
    0 Ram1234 over 2 years ago in reply to SandeepVarrier
