  3. Constrain manager Required and Actual Values
  • State Suggested Answer
  • Answers 1
  • Subscribers 161
  • Views 6564
Norb15
Norb15 over 2 years ago
Hi All!
First time using Orcad Capture/PCB Editor here from Altium Design. I am trying to set up the CM and one of the DRCs I am dealing with now is same net spacing. In the example below, it's pin to thru via same net spacing. I have set in CM so that the Required is "0 mm" and it does reflect it. I have done DRC update but it doesn't do anything. Anything I'm missing here? note that the actual drill hole won't be hitting the pins. idk if that is relevant.
Many Thanks!
layout:
DRC:
  • avant
    0 avant over 2 years ago
    In the physical constraints, there is a tab to set pad-to-pad contact to allow via and pad contact.
    Create a new physical constraint to allow pad-to-via.
    Then, create a physical constraint region using the allow pad-to-via constraint and create a constraint region shape at the drc area.
    It may be easier to understand by running a search on "setting a constraint region".
  • TCHA
    0 TCHA over 2 years ago in reply to avant
    @Norb15, can you provide an update on this? Is the issue resolved?
  • jc teyssier
    0 jc teyssier over 2 years ago
    The value for "no check es not "0" but "-1"
    Be aware to use such value only in an area creted specilly for this.
    Other solution: waive the drc and comment it to explain the decision
  • TCHA
    0 TCHA over 2 years ago in reply to jc teyssier
    • Vote Up +2 Vote Down
