  3. Different pad to pad spacing value
  • Views 6802
khuranav007
khuranav007 over 2 years ago
I would like to know how to handle this scenario in Cadence Allegro:
I have two pads, Pad1 and Pad2 and both are connected to different nets.
Say I have Pad to Pad spacing value of 50um and Pad to Shape spacing value of 100um - both defined in Constraint Manager.
Pad2 is flooded with shape (not completely, but partially - Pad2 net and shape net are same) and because of this I now want Pad1 and Pad2 spacing so that it is not 50um (can be 100um or 120um or 200um)
Can this be setup using existing constraints in Constraint Manager.  I would prefer that online DRC prevents this.
Thanks for any ideas.
  • John T
    0 John T over 2 years ago
    May I confirm the reason for the increased spacing? Currently I assume that the soldermask surrounding the pad is possibly the key issue here. Having a partially flooded pad means the exposed copper will come closer to the adjacent pad, effectively making the pad wider. Is this the issue you are trying to control? A snapshot would be useful to help understand the problem.
