  3. pcb db doctor
  • State Suggested Answer
  • Replies 12
  • Answers 4
  • Subscribers 167
  • Views 17758
pcb db doctor
nuPoli2023
nuPoli2023 over 2 years ago
I have this error when I try to open a symbol from a library created with orcad 16. I don't have any dbdoctor and I need your help to solve it
Thx
  • John T
    John T over 2 years ago in reply to nuPoli2023 +1 suggested
    Please let me know the Allegro installation version you have, as per the information in Menu: Help > About. I need to know this if we are to share the correct dbdoctor version with you.
  • SandeepVarrier
    0 SandeepVarrier over 2 years ago
    Which version are you trying to open this library the cadence installation will have the dbdoctor present you may use it to provide wild card entries from the folder where the libraries are present such as *.dra to update all the drawing files to the latest version you are using.
  • John T
    0 John T over 2 years ago
    Hi nuPoli2023, if you have the Allegro installation then you should have dbdoctor.  Assuming you are using a windows installation, please check by going to the "run" app in windows and enter "dbdoctor_ui".
    This should also be available in your start menu if you type "dbdoc" you should see an icon "PCB DB Doctor 20yy" or "PCB DB Doctor 17.4" depending on your installation.
    The ui should look like this:
    If not please let me know; I can then contact you by email to get a copy of this design from you.
  • nuPoli2023
    0 nuPoli2023 over 2 years ago in reply to John T
     Apparently there is no db doctor at all...
  • John T
    0 John T over 2 years ago in reply to nuPoli2023
  • John T
    As per my previous message I will need to know the tool version: 17.4, 22.1, 23.1?  I can then send you the appropriate program by mail once confirmed.
