  3. component dxf to footprint
  • State Suggested Answer
  • Answers 1
  • Subscribers 166
  • Views 7581
ankanphukan76
ankanphukan76 over 2 years ago
Hello Everyone,
Greetings of the day.
With reference to the above subject, I would like to inform you that, I have a component dxf file. I am unable to find the exact part number of the same.
I want to create the footprint of the component from the dxf file. Please help me.
I would be very gratefully.
Thank you for your time and support.
  • masamasa
    masamasa over 2 years ago +1 suggested
    this is how i usually do. first u import your dxf file into a symbol file (a dra file) then u copy or move the footprint pattern imported from the dxf file into the top surface (or bottom surface)…
  • ankanphukan76
    ankanphukan76 over 2 years ago in reply to masamasa +1
    Actually, to be very honest, I have a brief experience in creating new footprints from padstack editor. However, I have never tried to do the same directly from the dxf file. Could you take out some time…
  • masamasa
    masamasa over 2 years ago in reply to ankanphukan76 +1
    can u please tell us what kind of footprint u would like to create? can u put a capture image of the dxf file? if posting a capture image is a problem, a cartoon image would be fine as well.
  • masamasa
    0 masamasa over 2 years ago
    then u copy or move the footprint pattern imported from the dxf file into the top surface (or bottom surface) conductive layer.
    u may need to create a padstack for the footprint.
    then u assign pins
    then u save the dra file and create a psm file and a device file as well.
  • ankanphukan76
    0 ankanphukan76 over 2 years ago in reply to masamasa
    Actually, to be very honest, I have a brief experience in creating new footprints from padstack editor. However, I have never tried to do the same directly from the dxf file. Could you take out some time to help me out? Please guide me the steps.
  • masamasa
    0 masamasa over 2 years ago in reply to ankanphukan76
