  3. How to assign net name to a shape while using Z-Copy fu...
  • Views 9026
How to assign net name to a shape while using Z-Copy function
PCBTech
PCBTech over 2 years ago
This new feature in the Z-Copy function lets you assign a net name to a shape when you are copying it.
1) Select Edit > Z-Copy from the menu and then select the Class/Subclass onto which you want to copy the shape.
2) Toggle on the Assign option and select the net as shown below, in the Options tab.
3) After selecting the net, click the cursor on the edge of the shape which you want to copy, and you will see the shape copied. As you can see in the following image, the shape from the TOP layer is copied to the INNER 1 layer with the 1V2 net.
  • Byron365
    Byron365 over 2 years ago
    What version and hotfix of the tool is this available in?
  • steve
    steve over 2 years ago in reply to Byron365
    23.1 S001, all levels (OrCAD Std, Pro and Allegro).
