  3. 3D step file not exporting properly
  • State Suggested Answer
  • Answers 1
  • Views 8076
JITHINDEV
JITHINDEV over 2 years ago
I can export a Step file without any problem when I don't add the extra mechanical file (which is not provided in the schematic).
But when I add it, only the bare PCB shows up in the 3d step output. I tried exporting a 3D PDF and it worked fine.
The mechanical file I added is 230Mb in size. I have set the correct Library paths.
Do you know how to fix this issue?
  • TCHA
    TCHA over 2 years ago in reply to TCHA +1 suggested
    @JITHINDEV, any update on this?
  • TCHA
    0 TCHA over 2 years ago
    I understand that you are using the 3D canvas to export the step output and the 3D PDF. Can you try exporting step through the File > Export > STEP command and see how it comes?
  • TCHA
    0 TCHA over 2 years ago in reply to TCHA
  • JITHINDEV
    0 JITHINDEV over 2 years ago in reply to TCHA
    Hi TCHA,
    Thank you for your previous suggestion regarding the File > Export > STEP command. We revisited the issue and, with the help of my colleague, recreated the error. I have some updates to share.
    Symbol representation is set to: Step Model if available, else the Place_Bound Shape.  Symbols without an assigned STEP Model are displayed using the Place_Bound Shape. Creating 3D SILKSCREEN_BOTTOM with default thickness 0.5 mils because SILKSCREEN_BOTTOM is not defined in the cross section. Creating 3D PASTEMASK_BOTTOM with default thickness 0.5 mils because PASTEMASK_BOTTOM is not defined in the cross section. Creating 3D SOLDERMASK_BOTTOM with default thickness 0.5 mils because SOLDERMASK_BOTTOM is not defined in the cross section. Creating 3D SOLDERMASK_TOP with default thickness 0.5 mils because SOLDERMASK_TOP is not defined in the cross section. Creating 3D PASTEMASK_TOP with default thickness 0.5 mils because PASTEMASK_TOP is not defined in the cross section. Creating 3D SILKSCREEN_TOP with default thickness 0.5 mils because SILKSCREEN_TOP is not defined in the cross section.
    I want to mention that I have recently transitioned to another project, and while I cannot directly involve myself in this project, I am collaborating with my colleague to address the issue.
    Your continued assistance is highly valued.
