  3. How to use skill code to check pad to package geometry air...
  • Views 6379
How to use skill code to check pad to package geometry air gap?
ivy372
ivy372 over 2 years ago
Hi all,
I want to write a skill to auto check pad to package geometry air gap.
 <1.5mm : error
>=1.5mm : ok
Which arrgument can I use?
Thanks~
  • Tyler
    0 Tyler over 2 years ago
    You should be able to use the axlAirGap function to get the gaps that you need for your checks. You can get full details about the function at ...share\pcb\examples\skill\doc\funcs\axlAirGap.txt in your installation. I'm not sure which release or ISR you're using, so don't want to get into specific details of the function's use itself, in case the release I'm using is different than your own.
