  3. License Use Issue
  • State Suggested Answer
  • Answers 1
  • Views 9388
License Use Issue
BaldEngineer
BaldEngineer over 2 years ago
Hi
We are a team having 3 licenses. Sometimes, we experience that all the 3 licenses are locked up on a Single User even if they are using only 1 license.
So wondering what processes/applications under Task Manager should one look for to unrelease these licenses?
Would restarting the PC solve the issue? I feel there should be a more straight forward process to unlock all the licenses without going through Task Manager.
Last time it was Extracta application that was causing this issue, but not this time anymore.
  • TCHA
    TCHA over 2 years ago in reply to digital1 +1 suggested
    @BaldEngineer, is the issue resolved?
  • digital1
    0 digital1 over 2 years ago
    I believe you can reset it by using the LMTOOLS utility but you need to have administrator priveledges
  • BaldEngineer
    0 BaldEngineer over 2 years ago in reply to digital1
    I can give it a try. What's the procedure?
    Start/StopServer or Re-read license file?
  • digital1
    0 digital1 over 2 years ago in reply to BaldEngineer
    I am a single user so I dont know for sure but I would expect to stop the server wait for it to tell you that it has stopped then restart wait till it tells you it has restarted.
    As far as I know that should do it  you may have to reread the license file
    (I just have to reread the licence file if I have booted the pc without plugging the dongle in)
    Hope that helps
  • TCHA
    0 TCHA over 2 years ago in reply to digital1
