  3. Can't set airgap for pad separation
  • State Suggested Answer
  • Answers 1
  • Views 2343
CadenceUser0001
CadenceUser0001 over 2 years ago
I am not able to set my airgap to 3.8 as per datasheet. I can only go to 2.81 3.484 and 4.51 air gap spacing. How do I make it 3.8?
  • GilMay2
    GilMay2 over 2 years ago +1 suggested
    Try moving the pads by the proper increment to get 3.8 airgap. For example, if the airgap is 4.51, subtract 3.8 from 4.51 which is 0.71. Divide by 2, getting 0.355. Move left pad by 0.355 to the right…
  • JuanCR
    0 JuanCR over 2 years ago
    Hi!
    Have you tried modifying your horizontal grid settings. You can find this in Setup>Grids...
    Just keep in mind that there are separate grid settings for etch and non-etch elements as well as layer specific values.
    Let me know if this helped.
  • GilMay2
    0 GilMay2 over 2 years ago
    Try moving the pads by the proper increment to get 3.8 airgap. For example, if the airgap is 4.51, subtract 3.8 from 4.51 which is 0.71.  Divide by 2, getting 0.355. Move left pad by 0.355 to the right. ix 0.355. And move right pad by 0.355 to the left. ix -0.355. Hope this helps.
  • JuanCR
    0 JuanCR over 2 years ago in reply to JuanCR
    Hi! Any updates about this issue?
