  3. Check the pad to line of the "PACKAGE GEOMETRY/SILKSCREEN_TOP...
  • State Suggested Answer
  • Answers 1
  • Views 2107
Check the pad to line of the "PACKAGE GEOMETRY/SILKSCREEN_TOP" gap.
ivy372
ivy372 over 2 years ago
I want check all pads of the golden finger symbols to all other synbols layer of "PACKAGE GEOMETRY/SILKSCREEN_TOP" gap on the pcb board.
When the pad to the line is error then print a error report.
How can I fix the skill code?
skill as below :
PCB_dbid = axlDBGetDesign()
SYM = PCB_dbid~>symbols ;all symbols
SYM_GF = setof( x SYM  rexMatchp("GF" x~>name))      ;find golden finger symbols
SYM_GF_pins = flatten(SYM_GF~>pins)
SYM_other = setof( x SYM !member(x~>name  SYM_GF~>name))     ;find other symbols
SYM_other_pkggeoskt = setof( x2 flatten(SYM_other~>children~>segments) rexMatchp("PACKAGE GEOMETRY/SILKSCREEN_TOP" x2~>layer))
foreach(GP SYM_GF_pins
foreach(pkggeoskt SYM_other_pkggeoskt
air_gap = axlAirGap(GP pkggeoskt nil 'enhanced)
if(air_gap<1.5 then fprintf(Error_LOG "FAILED: The error is %L))))
  • DE202408202727
    0 DE202408202727 over 2 years ago
    One change required is:
    air_gap = axlAirGap(GP pkggeoskt nil 'enhanced) ->airGap
  • ivy372
    0 ivy372 over 2 years ago in reply to DE202408202727
    Hi Dave,
    Thanks your reply.
    But I still get error as below:
    Skill > foreach(GP SYM_GF_pins
    more> foreach(pkggeoskt SYM_other_pkggeoskt
    more> airGap = axlAirGap(GP pkggeoskt nil 'enhanced)
    more> if(airGap<1.5 then fprintf(Error_LOG "FAILED: The error is %L))))
    E-
    E- foreach(GP SYM_GF_pins foreach(pkggeoskt SYM_other_pkggeoskt airGap = axlAirGap(GP pkggeoskt nil 'enhanced)if(airGap<1.5 then fprintf(Error_LOG "FAILED: The error is %L))))
    E- ^^
    E- SYNTAX ERROR found at line 1 column 108 of file *string*
    E- *Error* lineread/read: syntax error encountered in input
    nil
    How can I fix it?
  • DE202408202727
    0 DE202408202727 over 2 years ago in reply to ivy372
    Add
    ->airGap
