  3. Unable to fins shape symbol path
  • State Verified Answer
  • Views 7318
Edit slide getting closed
Edit slide getting closed over 2 years ago
Hi team,
I have devloped shape symbols (.ssm) for any custom/irregular shapes that will be used in a pad stack.
I am not sure how to update this shape in this library. It would be really nice if some one could put some light on how to include this custom symbol in shape library.
We created name esp but not showing here. Please help any one.
  • AsbjornEdvalds
    AsbjornEdvalds over 2 years ago +1 verified
    Hi, Under the paths in the user preference editor within the PCB editor, you can find the "psmpath" variable. That variable defines the paths of shape symbols which both the PCB editor and the padstack…
  • AsbjornEdvalds
    +1 AsbjornEdvalds over 2 years ago
    Under the paths in the user preference editor within the PCB editor, you can find the "psmpath" variable. That variable defines the paths of shape symbols which both the PCB editor and the padstack editor uses. You can both use absolute paths and relative paths (relative to the file you have open).
    Hope this helps
  • Edit slide getting closed
    0 Edit slide getting closed over 2 years ago in reply to AsbjornEdvalds
    Thanks much. Issues solved
