  3. How to freeze/unfreeze a dynamic shape
  • Views 10514
mahimag
mahimag over 2 years ago
Before this release, dynamic shapes used to be automatically updated when interacting with other objects like vias, pins, and clines. The purpose of freezing shapes is to preserve the critical circuitry drawn using dynamic shapes, thereby maintaining the design intent. Starting SPB 23.1, Allegro X PCB Editor offers the freeze shape feature for dynamic shapes.
The shapes can be frozen by following these simple steps:
In the Shape edit mode, select the dynamic shape, and right-click and select Freeze Shapes. You can also go to the shape menu and select Freeze Shape(s) and click on the dynamic shape in the layout.
Dynamic shapes can be frozen along with vias having voids in the shapes. Dynamic shapes may also contain clines, pins, and so on. After freezing the shapes, when new entities such as cline, vias, and pins enter the frozen dynamic shapes, voids will not be created, and DRC will show up.
The Update Shape option can be used if you want to include newly added clines and vias into the frozen shape and it can be done by right-clicking on the shape and selecting Update Shape.
Once the shape is updated, the DRC that showed up will not be seen any more, as shown below. Void will be created around the cline and via even though the shape is frozen.
The number of frozen shapes in the design can be accessed from the following locations:
  1. Display > Status report, the count of frozen shapes can be seen.
  2. Shapes > Global dynamic Parameters in the shape fill tab
  3. Tools > Quick Reports > Shape Dynamic Status report; they can be also seen in show element and Find by query.
The frozen shapes can be unfrozen using the Unfreeze shapes option by right-clicking on the shape or from the Shape > Unfreeze Shape(s) menu.
  • masamasa
    masamasa over 2 years ago in reply to mahimag +1
    thank u for the explanation. this is a nice feature as i always have problems with shapes that was originally dynamic but changed to statc and back to dynamic.
  • masamasa
    This is a partial static shape over dynamic shapes, correct?
  • mahimag
    mahimag over 2 years ago in reply to masamasa
    Hi masamasa, I think Frozen shapes are update to Dynamic Shape.
    Dynamic shape is one whose fill is automatically updated to execute connectivity, generate voids, and run design rule checking to produce artwork quality output.
    Dynamic shapes are automatically updated when interacting with other objects, but you can now freeze the shapes without changing them to static.
    Once a dynamic shape is frozen, new objects entering the dynamic shape area will not void and generate a DRC error like with a static shape. You can manually modify shape boundaries on frozen dynamic shapes to maintain current voiding while avoiding new voids.
    I hope this helps!!
  • masamasa
  • mahimag
    Thanks for the feedback masamasa
