  3. Re-size and Re-space of differenetial pairs
  • State Suggested Answer
  • Replies 7
  • Answers 2
  • Subscribers 168
  • Views 9762
hailong9
hailong9 over 2 years ago
i'm try to change the width and gap of differenetial pairs, but it only works on the width of line. i can't respace the DP. how can I use this fucation to change the gap of DP?  is there some software can do this? Thanks!
  • hailong9
    0 hailong9 over 1 year ago in reply to zpofrp
    I haven't found a better way to solve this problem. Adjusting the line width and spacing always causes other issues, especially for curved differential pairs. So currently, I'm maintaining the pitch while only modifying the trace width to adjust impedance.
  • avant
    0 avant over 1 year ago in reply to zpofrp
    After setting the new width and spacing constraints, manually change the cline widths.
    Performing a slide on one of the traces will cause the spacing to change to the constraint setting.
    Often, this is faster than deleting and routing the diff pair.
