  3. Re-size and Re-space of differenetial pairs
  • State Suggested Answer
  • Replies 7
  • Answers 2
  • Subscribers 168
  • Views 9761
hailong9
hailong9 over 2 years ago
i'm try to change the width and gap of differenetial pairs, but it only works on the width of line. i can't respace the DP. how can I use this fucation to change the gap of DP?  is there some software can do this? Thanks!
  • steve
    0 steve over 2 years ago
    You could look at the Route - unsupported Prototypes - resize/respace diff pairs command, pick the diff pairs you are interested in and change the values.
  • DavidJHutchins
    0 DavidJHutchins over 2 years ago in reply to steve
    the info below is from another forum posting:
    The Resize/Respace Diff Pairs command ignores 45-degree traces when tolerances are set to 0. From Setup > Constraints > Physical > Differential Pair >  (+)Tolerance, set it to an appropriate small value, but non-zero. This will apply the modified spacing to the angled traces.
  • hailong9
    0 hailong9 over 2 years ago in reply to DavidJHutchins
    I change the value of  (+)Tolerance to 0.1. but it still isn't work. Display some error messages as show in the picture. "canot respace diff-pair segment at or near".
    Note that, the diff-pair contains arc.
  • GM202408077213
    0 GM202408077213 over 2 years ago
    Hi, did you resolve it? I have same problem, so i need some solution
  • zpofrp
    0 zpofrp over 1 year ago
    do you find a soluton for this question?
