  3. Calling scripts within the desired time intervals
  • State Suggested Answer
  • Answers 1
  • Views 7138
DPGDA
DPGDA over 2 years ago
I would like to prepare either script or skill function that would perform some tasks within the desired amount of time.
I've seen the hiRegTimer() function as a SKILL process, but it does not work in Allegro products (or I cannot use it properly).
Ideally, I would like to open the PCB design, then the popup window appears asking for the interval value and then the script executes predefimed commands within the set intervals.
  • JuanCR
    JuanCR over 2 years ago +1 suggested
    Hello DPGDA, You are aware of the hiRegTimer() function - this can be used to schedule functions to be called at a number of tenths of seconds in the future, provided that the top level user interface…
  • JuanCR
    0 JuanCR over 2 years ago
    Hello DPGDA,
    You are aware of the hiRegTimer() function - this can be used to schedule functions to be called at a number of tenths of seconds in the future, provided that the top level user interface is not blocked. This works well, but it is only a single-shot execution. If you want repeated execution, you need to get the function to submit another hiRegTimer call, and so on.
    I understand you would like a convenient way of setting up and managing repeating jobs.
    The following SKILL code provides such a solution. The comments in the code give examples of its use - when you submit a job, it returns an identifier - that identifier can be used to terminate a repeating job. As a result, multiple concurrent scheduled jobs can be easily managed with the package.
    You should however take care not to schedule anything that is too lengthy to run, since this will appear to occasionally freeze the user interface as the scheduled task runs.
    You should avoid loading the CCStimer.ils code more than once within the same Virtuoso session. Doing so will lose information about any currently scheduled jobs and will also cause the same job ids to be re-used. This can have the effect of causing recently terminated jobs to run multiple times. If you are loading the code from a SKILL script which may get loaded again later, you should consider using this snippet of code to avoid the file being loaded twice:
    unless(boundp('CCStimer)
      load("/path/to/CCStimer.ils")
    The SKILL code is given below:
    /* CCStimer.ils
    Language   SKILL
    Date       Sep 17, 2007
    A package for scheduling timer jobs, either one off or
    repeated. The scheduler returns an id, and this id can
    also be used to terminate the scheduled job.
    ; schedule a one-off job
    job1=CCStimer->schedule("println('hello)" 50)
    ; schedule a repeated job
    job2=CCStimer->schedule("println('goodbye)" 50 ?repeat t)
    ; terminate the repeated job:
    CCStimer->terminate(job2)
    Can also schedule functions of one argument (the id):
    CCStimer->schedule(lambda((id) printf("Job id is %d\n" id)) 30)
    This example works in SKILL++. It uses a lambda function and
    a lexically scoped counter to terminate the repeating job after
    a specified number of times.
    (defun CCSrunNTimes (command time ntimes)
      (CCStimer->schedule
       (lambda (id) (if (greaterp ntimes 0)
                        (errsetstring command t)
                        (CCStimer->terminate id))
               (predecrement ntimes))
       time
       ?repeat t
    ; print out a message 10 times, every 2 seconds.
    CCSrunNTimes("println(\"hello\")" 20 10)
    Note - this code uses SKILL++ semantics, and so should keep the
    ils suffix.
    SCCS Info: @(#) CCStimer.ils 10/10/07.13:01:45 1.2
    *  DISCLAIMER: The following code is provided for Cadence customers to use at  *
    *   their own risk. The code may require modification to satisfy the           *
    *   requirements of any user. The code and any modifications to the code may   *
    *   not be compatible with current or future versions of Cadence products.     *
    *   THE CODE IS PROVIDED "AS IS" AND WITH NO WARRANTIES, INCLUDING WITHOUT     *
    *   LIMITATION ANY EXPRESS WARRANTIES OR IMPLIED WARRANTIES OF MERCHANTABILITY *
    *   OR FITNESS FOR A PARTICULAR USE.                                           *
    (importSkillVar CCStimer)
    (setq CCStimer
          (let (
                (timerIdTable (makeTable 'timerIds nil))
                (nextId 1)
            *      (schedule callback tenthsSeconds @key repeat "txg")     *
            *      Exported function to schedule a job. The job is a       *
            * specified callback string, and it will be executed at least  *
            * the specified tenths of seconds in the future. If ?repeat t  *
            *    is passed, the job will be rescheduled once executed -    *
            *          otherwise it will only be scheduled once.           *
            *         Returns an identifier (integer) for the job.         *
            (defun schedule (callback tenthsSeconds @key repeat "gxg")
              (let (newId)
                (unless (or (stringp callback) (symbolp callback) (procedurep callback))
                  (error "schedule: callback must be a string, symbol, or function object: %L\n"
                         callback)
                (setq newId (postincrement nextId))
                (setarray timerIdTable newId
                          list(callback tenthsSeconds repeat))
                (hiRegTimer
                  (sprintf nil "CCStimer->execute(%d)" newId)
                  tenthsSeconds
                newId
            *                      (terminate id "x")                      *
            *  Exported function to terminate a job, given an id. Returns  *
            * t if the id was terminated, nil if the id didn't correspond  *
            *              to a job that is still scheduled.               *
            (defun terminate (id "x")
              (remove id timerIdTable)!=nil
            *                       (execute id "x")                       *
            *     Exported function - only expected to be invoked from     *
            *     inside the timer scheduled by the function schedule.     *
            (defun execute (id "x")
              (let (jobDetails)
                (setq jobDetails (arrayref timerIdTable id))
                (when jobDetails
                  (if (stringp (car jobDetails))
                      (errsetstring (car jobDetails) t)
                      (errset (funcall (car jobDetails) id) t)
                  ; If the repeat flag was set, schedule it again. Otherwise
                  ; delete the job details
                  (if (caddr jobDetails)
                    (hiRegTimer
                      (sprintf nil "CCStimer->execute(%d)" id)
                      (cadr jobDetails)
                    (terminate id)
                  ) ; when jobDetails
                ) ; let
              ) ; defun
            ; Return DPL with exported functions
            (list nil
                  'schedule schedule
                  'terminate terminate
                  'execute execute
            ) ; let
          ) ; setq
    This was taken from an article on COS, which you can find here:
    Article (11381132) Title: How to schedule a repeating function with a timer in SKILL
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nZocEAE
