  3. Making traces skeletal and pads hollow as default whenever...
  • State Suggested Answer
  • Answers 1
  • Views 6679
Making traces skeletal and pads hollow as default whenever opening a design or symbol regardless of its inherited settings?
Ulf K
Ulf K over 2 years ago
Greetings.
I wonder if there is a way to make the PCB Editor always start with traces in "Skeletal" view and pads "Unfilled" mode.
If saving a board or symbot in those modes, the modes are preserved if and when they are reopened. Designs created
and saved in other "visibility" modes appear with filled traces and pads.
I have been looking for a setting that could be used to override the defaults (preserve display mode) but found none.
Another question is why the trace/shape/shadow display mode (opacity) is located in the color menu but the pad vilsibility
setting(s) are in the design setup canvas.
The design setup menu can be invoked without loading a board or symbol, but if having set the parameters and then
proceeding with board or symbol load, the settigs are lost.
  • steve
    0 steve over 2 years ago
    One method would be to record a script of you setting up Allegro with those display settings. Once recorded there is a solution on COS that explains how to replay that script on start-up:- How to automatically replay a script when starting Allegro PCB Editor (cadence.com)
  • Ulf K
    0 Ulf K over 2 years ago in reply to steve
    ...Followed the link. All frames/boxes were empty. There were descriptive texts but it seems easier just to adjust the settings whenever opening a design.
