  3. Nets in the PCB layout not respecting the spacing rules...
  • State Suggested Answer
  • Replies 13
  • Answers 1
  • Views 13158
Nets in the PCB layout not respecting the spacing rules provided in the constraint manager
RohitRohan
RohitRohan over 2 years ago
When i am routing the nets in the PCB board i can see that the nets which i routing in the PCB board are not respecting the spacing rules provided in constraint manager. The 2 nets come close to each other normally they should shove, but in case the PCB board which i working, the 2 nets even though different net names when the nets come close to each other instead of shove the nets are overlapping to each to other. In analysis the spacing constraints are enabled but still the nets are overlapping with each other. May i know why the issue is occurring. I have run the DB Doctor also on the PCB file but same results. Currently i am using version 22.1 PCB editor.
  • RohitRohan
    RohitRohan over 2 years ago in reply to RohitRohan +1
    Hai Steve, the problem was the Default rule in the spacing was renamed to other name which was causing the PCB editor tool to not take the value to spacing constraint value, so i had change the name back…
  • steve
    0 steve over 2 years ago in reply to RohitRohan
    Does this happen on every design you have? If its only this design I would probably need to see a board file to debug this any further so maybe raise the issue with Cadence/Channel Partner direct so they can get the actual board file
  • RohitRohan
    0 RohitRohan over 2 years ago in reply to steve
    Actually this problem is occurring only for one PCB board and not for others, i have raised the case with Cadence team also and waiting for there reply.
  • RohitRohan
    0 RohitRohan over 2 years ago in reply to RohitRohan
    Hai Steve, the problem was the Default rule in the spacing was renamed to other name which was causing the PCB editor tool to not take the value to spacing constraint value, so i had change the name back to Default and problem got resolved.
