  3. distance to fillets (teardrops)
  • State Suggested Answer
  • Replies 9
  • Answers 1
  • Subscribers 159
  • Views 7578
masamasa
masamasa over 1 year ago
hello:
is there a way to find out a distance between objects and a fillet?
  • eDave
    0 eDave over 1 year ago
    A fillet is a shape.
  • masamasa
    0 masamasa over 1 year ago in reply to eDave
    thank u, dave.
    i was able to catch the fillet by turning all objects on on the find filter.
    actually this fillet distance violates the minimum cline spacing on the constraint manager.
    is there a way to set up the minimum distance to fillets so that it gets an error on drc?
  • eDave
    0 eDave over 1 year ago in reply to masamasa
    I'm not sure but check your constraint values. Line to Shape?
  • VVRD
    0 VVRD over 1 year ago in reply to masamasa
    You can adjust offset values in Route-> Teardrop/Tapered Trace -> Parameters  "Fillet and Tapered Trace" window,
  • masamasa
    0 masamasa over 1 year ago in reply to VVRD
    thank u for your response.
    which setting do i need to adjust for a space between fillets and objects?
