  3. Single Trace Model in enabled and grayed out while routing...
  • State Suggested Answer
  • Answers 1
  • Views 8467
Single Trace Model in enabled and grayed out while routing the differential pair
RohitRohan
RohitRohan over 2 years ago
I have create a differential pair for 2 nets but while performing the differential pair routing in the PCB editor, the Sigle Trace Model is enabled and i can't uncheck it because the option is grayed out. (Below image for reference)
  • VVRD
    VVRD over 2 years ago in reply to VVRD +1 suggested
    Please check the below article from cadence site, https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nSuyEAE
  • RohitRohan
    0 RohitRohan over 2 years ago
    Single Trace Mode option actually which is grayed out while doing differential pair routing
  • VVRD
    0 VVRD over 2 years ago in reply to RohitRohan
    It is not grayed out at my end when I tried to do differential pair routing
  • VVRD
    0 VVRD over 2 years ago in reply to VVRD
