  3. Product option not showing properly in Allegro X version...
  • State Suggested Answer
  • Answers 1
  • Views 9694
Product option not showing properly in Allegro X version?
Kabaleeswaran
Kabaleeswaran over 2 years ago
Hi Team,
Following Product shown in another person PC. but same product not able view in PC. if open Allegro PCB editor it is open automatically when license is free. it is chosen PCB designer only. if license is reset cache or number of license occupied layout file is not opening . this below window is not shown any time. Kindly help any one
  • mahimag
    mahimag over 2 years ago in reply to Kabaleeswaran +1 suggested
    Hello Kabaleeswaran , Yes looking at the screenshot it looks like tool is not able to get the license file. Before that can you try the below steps once: 1. Go to your HOME directory by typing %HOME…
  • mahimag
    0 mahimag over 2 years ago
    Hi Kabaleeswaran, If the product choices dialog box does not come after invoking the software, it might be because the user selected the Use as default option.To address this, once the software is started with the default choices, go to File > Change Editor and select the new product license from the list provided.
    Also, the default selection is stored in the appropriate allegro.ini file. This file can be found in your pcbenv folder (<HOME>/pcbenv/allegro.ini), located under the HOME directory path. It is stored as base_license=Allegro_Adv_Packaging_Plus. If this line is deleted, the default selection is disabled . Now if you reinvoke Allegro you can see the changes.
  • Kabaleeswaran
    0 Kabaleeswaran over 2 years ago in reply to mahimag
    i tried it is not working.. can you suggest me where i need to add
    [allegro]
    directory=C:/Users/athira.m/Syrma Technology/eCAD - eCAD Hub/Master Library/Controlled Library/Allegro Library
    toolbar=1
    version=22.1
    appm_autodrag=0
    appm_shpsel_shpfill=0
    appm_singleclick=0
    appmode=generaledit
    [plot_setup_v2]
    setupAutoCenter=1
    setupColor=0
    setupContents=1
    setupDefaultLineweight=1
    setupMirror=0
    setupScaling=0
    setupScalingFactor=1.000000
    setupVectorizeText=0
    setupVectorizeTextWidth=0.000000
    windowsNonVectorText=0
    windowsNonVectorTextFont=Courier
    windowsNonVectorTextFontScaleHeight=100
    windowsNonVectorTextFontScaleWidth=100
    windowsPlotMargin=0.250000
    windowsColor=2
    windowsCopies=1
    windowsDefaultSource=15
    windowsOrientation=1
    windowsPaperName=Letter
    windowsPaperSize=1
    windowsPrintQuality=600
    windowsPrinterName=Microsoft Print to PDF
    [allegro_free_viewer]
    appm_autodrag=0
    appm_shpsel_shpfill=1
    appm_singleclick=0
    appmode=ucpedit
    directory=C:/Users/athira.m/Syrma Technology/eCAD - eCAD Hub/Design Files/On_progress_Designs/LIG/LIG_MCU/02.DESIGN_FILES/26FEB24
    toolbar=1
    version=22.1
    i found one more observation i am confusing is that license fetch from server  or local , bcoz i am facing issue. can you suggest me
  • mahimag
    0 mahimag over 2 years ago in reply to Kabaleeswaran
    Hello Kabaleeswaran, Yes looking at the screenshot it looks like tool is not able to get the license file. Before that can you try the below steps once:
    1. Go to your HOME directory by typing %HOME% in the Windows Run dialog box.
    2. Open the pcbenv folder and rename “allegro.ini” to “allegro_backup.ini”.
    3. Delete the old license_cache files present in this folder.
    4. Now, when you run APD+/Allegro, a new allegro.ini will be created.
    See if you can access the license now.
