  3. Non-plated mechanical hole not following the spacing rule...
  • State Verified Answer
  • Views 8367
Non-plated mechanical hole not following the spacing rule in Constraint manager.
TiffanyB
TiffanyB over 2 years ago
I'm using Allegro V17.4 for my layout. I assigned 10 mil rules for Hole and Thru pin away from Shape in the Constraint manager. But the backoff only came out to be 8 mil from GND shape. The shape and the non-plated mechanical pin for the connector don't have any special property tie to them. The padstack doesn't have Anti Pad or Kee pout assign to it and I do not have Route Keepout shape on top of the hole. Please advise.
  • oldmouldy
    oldmouldy over 2 years ago +2 verified
    "holes" are left by Pad Suppression, they are not Mechanical Holes. The Mechanical Hole spacing is controlled from the Constraint Manager, Analyze>Analysis Mode, Design, Mechanical Spacing and the default…
  • GilMay2
    0 GilMay2 over 2 years ago
    Hello Tiffany,
    I'm having the same exact trouble. Perhaps this is a bug?
    The work-around:
  • oldmouldy
    0 oldmouldy over 2 years ago
    "holes" are left by Pad Suppression, they are not Mechanical Holes. The Mechanical Hole spacing is controlled from the Constraint Manager, Analyze>Analysis Mode, Design, Mechanical Spacing and the default spacing value is 8 Mils, 0.203mm.
    • Vote Up +2 Vote Down
  • TiffanyB
    0 TiffanyB over 2 years ago in reply to oldmouldy
    Thank you so much for your explanation.
